Now that things are cooling down people with Doors and use their cars in cooler weather this mod might Interest you. If your using your doors you will notice quite a bit of cold air coming threw the cab from the Fire wall that’s what they call it on a car but on the gem it’s (the most forward plastic wall) between you and the motor. The car has 3 holes where air and water can come into the car. #1 Ebrake
#2 steering shaft #3 Wire Harness
Here is the factory hole for the Ebrake
Here is the steering shaft
