I thought I was start a new tread about these new gearbox’s from Rodney @Old_Houseboater
These are 10:35 (stock GEM are 17:1) classic gearbox’s and new axels that allow you use them in a 2016 or newer GEM car. These gearbox’s are MUCH quieter than stock and allow you to achieve almost 40mph from an otherwise stock GEM car. The only modification needs is to drill four new mounting holes for the factory mounting brackets. Very easy modification.
Here are some pictures and speeds ( a stock GEM car turns 6000RPM)
