What are my options to repair or replace?
our 2015 E4 has felt like there’s something a little lose in the front end. Just a slight clunk over bumps. Haven’t looked into it but it bothers me and I need to try to find the culprit. Ball joint, tie rod end, bushing?
What is your symptom?
Saw those, good upto 2012, they changed 2013-15. Working with them now to send specs and see if they can source aftermarket. They don’t do 2013+ parts but I am going to try and help them start caring aftermarket parts for these years.
Blake, jack up, remove wheels. Pull A arms hard back and forth and see if they move at bushings, then yank up and down next to ball joints. mine moved 1/8" .
ok polaris number 1543070 change to 1543308 will also fit rear 2005-2012 cars
and 2013-2015 front and rear
