Problems
No Power to controller
No 12v power
No LCD Power
Things that have been done
new batteries
new motor 1 yr old
have 72-74v power everywhere until it gets to the controller (i believe)
I checked the power on pin one of the motor control and there’s nothing.
Trying to figure out what I’m missing I’m kind of at a stand still.
If apply 12v power to the display fuse it does come on. But other than that i’m lost on where to go next
If the cart is on should I have 72v at the motor controller main power supply?
I just checked the red and black wires coming from the charger and it reads 72v. The manual says to replace DC/DC converter/charger assembly. Does that mean both or maybe one or both could be bad?
I’m trying to make sure there’s 72v going in and 12/3v out but still reading on what pins to check.
Thanks for the proper manual. The one I had was from 2012.
So, I tested both 72v, and 12v and came to the conclusion I might need a new converter (as suggested) I was getting 72v everywhere but no 12v
New converter, everything came back on, butttt…
No movement.
The LCD comes on but the battery is showing one solid red bar but the other bars are flashing as well as the tool icon, the temp icon and all 3 drive settings.
No mileage either
It’s measuring 73+ on everything
Tested all the batteries and I’m getting around 14.1v on all but one, 13.3v
Batteries bad?
Than is again for the help and the right directions
