Ok on to the next issue abs probably last
2005
When you hit the brakes the lights turn on as they should
When you let off they turn off like they should
But then 5 seconds later the brake lights turn back on and stay on constant until you press brakes again
I greased the switch behind peddle
That did nothing
I have a feeling it has to do with this switch
As when I unplug it the lights go off.
