Sure.
A padded envelope is less than $10.
You have money
Thank you
I hope you do better than Grant.
It’s been a while so your on your own. Paper work is with it.
Modified to connect to MM. Any speed.
Rather than the jumper this plugs in.
rfid needs 12v.
No other wiring. Might work with a 9v battery for testing. I’ll try it before shipping.
If you get time send a dollar for goods and service. Then PP will print me a label.
Thanks, I plan to use it for the ignition not the MM - I blew up the other one when we blew up the DC controller. Opps. Wiring diagrams are very help BEFORE you start. Lesson learned.
Sorry sent as friend as I thought otherwise they charge you. I can PM you the address but it would be the same as the MM from Monday. - oh, just re-read your message - hold for label.
Yeh, that’s how I get it both ways.
Just lazy, I can click and ship from a $1 payment.
9v works fine.
Grant said the light never came on for him.
Connect a 9v and led will come on if fob is near. If it doesn’t, no sense going further.
Time delay on and off.
Don’t remember testing it with the MM and never went further as the project seemed jinxed.
That worked. It’s on the way.
