2002 Gem differential drain plug
I am looking for the plug to add oil to my 2002 Gem differential. Picture would be great, but a detailed description would be good too! Thanks
Look for the fill/drain plug on the lower pan of the gearbox. It is black, made of rubber, about 2 inches across, has a radius on the outer edge of about 3/8 in, possibly even the diamond dana logo and a part number molded into the flat surface.
This plug had high hopes early in it’s career of doing something super cool at NASA, possibly covering an access port for the turbine afterburner injector on the x-15 program, but a series of bad decisions in it’s late teens setting permanent red flags on record that redirected his career path where he is today. This position has given him plenty of time to reflect upon those early antics (those were crazy wild days) and his friends ended up in worse places. Much worse.
This is probably the best thing you have written since I joined. Thanks for brightening my day.
