Hi does anyone know of a AC conversion kit for a 2002 Gem Car. I can find some AC motors but I can’t find a wire harness with direction for the Gem Car. Thanks
If you can find the motor and controller, the rest should be easy.
Lots of help on here.
What did you find?
I posted some kits in previous thread.
I doubt it’s worth the money. What are your expectations?
AC motor has more longevity, gets more mileage on a charge and more horse power. I added the link to AC kit.
No link I could see.
Sorry about that. I am afraid that I won’t be able to connect all the wires up correctly. I was hoping that I cou of find a AC wiring harness for a 2002 Gem car. Where do i find the comments you posted about Gem cars AC conversion kits.
My old thread had little info.
I see they do make a 72v version.
Ask the for a Gem reference.
Another member swapped controller brands and they built him a harness.
Unless someone needs a motor and controller, $3k is a bit steep.
Price won’t deter the hotrodders.
It will be interesting to see how one of these performs next to Grant’s high voltage Gem.
Do you know if the 2002 Gem car accessories has a separate wiring harness than the one going to the controller? Thanks
I, too, have been looking for that sane wiring harness. Only mine is a 2000 E825. I’m wondering if I may have to buy one from a different 72v cart to make it fit. Based on my research, I know some of the Ezgo RXVs have that same 23-pin connector, but I’d need to check their wiring diagrams to confirm it.
Our kits use the oem wiring.
Hey there! You might want to try emailing Navitas. I think they have a partner who works on those Polaris Gems, but I can’t remember the name right now. Good luck!
