#1 Probably the most basic question one can ask but can someone please tell me how many volts the hot side of my key switch should read all the time and what both sides would read when i have the key switched on ?? I have a simple 2 pole switch from NAPA on there. Where should i be pulling the ground from to measure the key switch? Chassis? Controller Neg? 1st Batt Neg? Last Batt Neg?
When grounded to:
Neg of battery #1 which is directly behind the rear drivers seat……..
switch off….30V hot side…21.5v switched side
switch on….30v hot side…30v switched side
Neg of battery #6 (which i believe is the last batt in the series top shelf under hood?) please correct me if i am wrong.
switch off…4.5v hot side…..13.7v switched side switch on…4.1 v hot side….4.1v switched side
Neg of controller…
switch off…30v hot side…21v switched side
Neg to chassis (I used the horn ground here)
switch off..13.3v hot side…0 v switched side switch on…13.3 hot side…13.3 switched side.
Pulling from #1 batt neg to #6 Batt pos i am reading 78.5v.
Can someone tell me what is the “main battery pack” please? In everything i read or watch everything is always off the “main pack” but when you have 6 batteries i am unclear as to what that is referring to and if i should be pulling off the neg of one battery and the pos of another or is it off one battery or a location under the dash?
There is a few reasons i need to figure this out.
I am trying to install a little battery fuel gauge to come on when i switch the key on. Problem is when I have it grounded and touch it to the hot side of the key switch i get nothing but when i go to the batt and touch neg and pos respectively it works. Any thoughts or direction on this one?
I am also trying to install a 5 pin 72v relay in front of a 72v step down converter in front of a fuse box for more accessories thinking i am doing the right thing when it comes to adding lights, soundbar blah blah blah. Am I ? I believe I have the updated converted in the Gem which some said i could use for the accessories but I would still like to install the equipment i have just because i have it now and also to learn the way this voltage stuff works on this thing. I want the converter to power on when i turn the key on which the converter is capable of doing but at this point i am looking for help because i wired everything up the way the diagram shows (without the relay in line yet) and popped the 20amp fuse on the converter. I have attached a few pics so you can see what i am working with. Anyone willing to help me out on this one? Again i would like to add the relay in front of this converter unless the converter’s key switch wire is doing the same thing the relay would do and only be drawing power if the key switch is on? I appreciate the advice in advance gentlemen. Hopefully i can get some guidance and get this thing wired up for my daughter by the weekend.
