New to me 2001 rebuild is going well. New brakes, wheels, half-shafts, etc. I am down to thinking about the motor. I’m surprised how loud it is. No grinding, just a loud high-pitched electric motor noise. I don’t know what ‘normal’ is, but it’s louder than a regular golf cart and takes away from the ride quality.
I’m wondering if the rubber bushing/bumper is bad or what could be causing the noise? If it is normal, are the R4F/D&D motors quieter?
- What is the history of this motor? Has it been serviced lately?
- Does this noise also happen in reverse?
Lift your front wheels off the ground so you can run it in place.
- Does it still make this noise?
Unloaded, it might be less. This might mean what you are hearing is input shaft gear noise. Have you checked the oil level in the gearbox?
With it running in place (watch out for the spinning wheels) you might be able to isolate the area where it is coming from. Use a stick and place your hand on one end of it with your thumb knuckle wrapped over the end. When car is running, lean into the car and place the stick in various spots and place the end of your stick/thumb knuckle up to your earlobe and give things a listen. As you move the stick around you will be able to listen to various moving parts. Place it on outside of motor bearing, Where the brushes are, and the various shafts and their bearings in your gearbox.
Do you think you can figure out how to record, post the video somewhere, and link to it here in your next post?
Thanks for the reply!
I’ve got the rear subframe jacked up right now for some touch up painting, but will hopefully be able to run the motor and record a video in the next day or so. In the meantime, some info below.
** What is the history of this motor? Has it been serviced lately?*
Original from 2001 (3.5HP?). 5,300 miles. Cart was stored indoors, but I don’t think it has ever been serviced other than new batteries. Inherited from father-in-law, so can no longer get the details.
** Does this noise also happen in reverse?*
Yes, but I haven’t gone as fast, of course. The noise builds with speed. Not bad at low speeds.
Will try to do this when I can.
No. That is a good call. I should probably do a change regardless.
@AssyRequired Here’s a short video of the motor noise. I did change the gearbox oil before recording this. Not much difference. Maybe this is normal, but sounds louder than it should be to me.
For what it’s worth, there isn’t a performance issue that I can tell. Gets up to 25mph.
From what I can tell, that is just normal gear whine.
It is partly due to the while driveline is solid mounted to the frame.
What oil did you put in? Yes, the manual says something like 30wt motor oil. Most people ignore that and put in 90wt gear oil.
Thanks for giving it a listen. So a new D&D motor would have a similar noise? Do you think I should change the bushing after ~5,300 miles or not really needed?
Yeah, I did just use SAE 30, but agree with the sentiment. I might drain some back out and put in the thick Lucas stuff to supplement.
Yeah, a new motor will still sound the same.
90wt will quiet it down even more. Lucas motor honey additive will help even more.
You may notice range may suffer each step due to it being tougher to spin.
I wouldn’t worry about changing the bushing (rubber bumper?).
I have a 2002 with a very similar whine while going forward. Seems to be getting louder lately. Im not sure if it’s the motor or the gears. I don’t think the motor has ever been touched. I recently changed the differential oil. Installed the recommended straight 30 weight which made no difference at all with the noise. Today I tried going in reverse for a few hundred feet and to my surprise it was extremely quiet. Slight whine when going in reverse but let off the accelerator. Is that an indication of the motor or the gears?
@PandD - I think you missed the point of this topic.
Try some 90wt.
Report back with how it goes.
(something sunol did NOT do)
I might try the heavier oil as an experiment but I don’t think I would keep it in there even if it quiets the noise. The upper input bearings are lubricated by the oil splashing around inside the case. A heavier gear oil can get very think especially in the winter with the colder temps. This is just my opinion but I don’t think those upper bearings would be properly lubricated with a heavy gear oil. From my automotive days I know how think gear oil can get when the temperature drops.
The 30 wt was to squeeze an extra couple miles range ftom the bateries
90wt is the not the oil you are looking for. (Jedi sith wave) its a 2002 canola oil works great. Even better, ask yoir local Long John Silvers fish fry place for a quart of used fryer oil.
91 octaine works best in the 00-04 gearboxes. Only the best for your little gemmy. Beep. Beep.
I will add my two cents here. Yes, the noise does sound rather normal to me. A newer stronger motor may be a bit quieter. Just just judging by my experience with shop grinders, a Baldor motor seems quieter that the Harbor Freight one. That said changing the gearbox oil is always a good thing. I added some Lithium gear grease to mine. But, if the noise was coming from the gearbox changing oil won’t solve it. It will delay the inevitable destruction of it. But, once gears get bad spots on them they only get worse. Bad gears whine and bad bearing roar! And, as AssyRequired said, the drive being bolted directly to the frame would make it loader by transmitting the vibrations, the sound, through the body of the cart, kinda like a speaker.
@PandD - What is your status?
Since it has been a month (or 2?) since your last post, can you provide any info from your testing? (30 vs 90w)
Checking back in with results is what makes the archives here a valuable resource for current and future gem owners seeking answers.
I will add some further thoughts.
- The thicker oil should provide some additional padding between the gear teeth
- If the thicker oil carries all the way up to the input gear, it will have a habit of squishing out from the meshing gear teeth and outwards to both of the bearings. (observed by twiddling lucas gear display)
Lithium grease…
“You got your battery on my spline!”
“No you stuck your spline in my bayttery!”
And this is why the Reses peanut butter Corp was forever banned from medical products and adult toys.
