I have looked all over and can not find this fuse. It is not one of the 3 under the seat as they all test good. Wiring schematic shows it in the circuit for the above but I can not locate it. Any help (with picture) would be gratefully appreciated. Thanks.
The fuse is under the hood towards the back. If you need a copy of the service manual send me your email.
Sent, let me know if it doesn’t show up.
I have found several mistakes in the manual. Mostly in the pinpoint tests where the result will tell you to replace a part but it’s incorrect. Luckily I’ve been in the industry for many years and realized the manual was wrong before buying the parts. It’s mostly common sense but ask before buying a part if you’re unsure.
