It is common for our GEMs to stay red for more than an hour if the batteries are low. Check the voltage of all batteries together. Your reading should be in the high 70’s. Check that the battery cables are connected properly. this is a common problem when changing batteries. Do you know what mode the charger is set to? GEL, AGM, and flooded batteries all require different charging profiles for maximum performance and battery life. The correct setting for flooded batteries is “F”. It is okay for batteries to become slightly warm when charging, but they should not get hot or release rotten egg smell into the air.
[QUOTE=GEMmechanic;12213]It is common for our GEMs to stay red for more than an hour if the batteries are low. Check the voltage of all batteries together. Your reading should be in the high 70’s. Check that the battery cables are connected properly. this is a common problem when changing batteries. Do you know what mode the charger is set to? GEL, AGM, and flooded batteries all require different charging profiles for maximum performance and battery life. The correct setting for flooded batteries is “F”. It is okay for batteries to become slightly warm when charging, but they should not get hot or release rotten egg smell into the air.
How do you know how to make sure your charger is set for the right batteries? I recently changed my batteries and the charger doesn’t charge them, when they get below 50-60% I have to charge them individually and then the onboard charger will take them to about 90% or so, I have the same batteries that were in it before, it’s driving me nuts. I had a guy look at it and he said that it’s the charging system, I’ve already put $800 in batteries in it, the zivian charger is about $500-600, I’m actually tired of putting money in the damn thing
The zivan NG1 are 20 years old now. It might be bad, depends on how it got used. 20 years is a long time for that kind of electronics.
Take the dash off, unplug the din connector. You’ll lose the led on the pod, but it will tell if you have a bad temp sensor.
There should be a round cover up sticker on top of the charger. There often is a micro dial under it. Cross reference that setting to the chart on the front of the charger.
A pirate walks into a bar with a ships wheel hanging from his belt buckle. The bartender points this out and it’s close proximity to his privates. The pirate nods slowly and says "Arrg…
