19 miles an hour and sluggish
Dead spot under acceleration.
Driving on DL the 2012 GEM cart is sluggish but doesn’t have this problem. Shift to DH and it will quickly accelerate to 19-21 mph and then it hits a flat spot and won’t go any faster on the level or climbing a hill. Downhill it has will pass through that dead spot and once it reaches 23 will again accelerate strongly again up to 26-27mph (even up hills).
My 7hp GE motor was just rebuilt by Rodney, and he loaned me a 5 hp to test, it ran perfectly without any hesitations right from zero to 30. BTW it IS a 12:44 gear ratio. The power is controlled by a T-4 from a LithiumGod Extended Range Di-lithium pack. It is running a Magic Magnet, and switched to kilometers, numbers are close to accurate.
I calculate 4000 RPM where the dead spot begins, and my V-max of 27mph is turning 5000 rpm.
I’m guessing someone has seen exactly this issue and can offer some words of wisdom.
R.
