Any know the specs of the new 16” OEM wheel option? Specifically the offset??? I have read through the terrific wheel threads on here and learned a lot. I like how the 16” GEM wheels “stick out” a bit and really give a wider stance. I would like to replicate that look and wondered what offset and spacer combo was used
16" offset? Damn… dat’s a donk gem.
No, it’s a 16” wheel. Not sure what the offset/spacer combo is—that is my question
| jrjava
December 5 |
Lol I was expecting something like that from you ![]()
That is a GEM factory aluminum wheel. It has no spacer.
No spacer, then you’ve seen one. Measure it.
Not necessarily or necessary. Measure from mounting face of wheel both ways. Zero offset will be same both ways.
Should get close without removing wheel.
I was able to find this evening in an online parts catalog that the 16’s are 6.5 wide and as mentioned several times on here are 4x115. No offset is listed although the 14’s state an offset of et11
