Finally got the charger working was a bad wire connection now it makes no noise just blinks red. Is this good or no?
The fan has to turn on…and u can here esp on startup
Yeah I can hear the fan and when it starts up it’s pretty loud but it stays pretty consistently loud. But then it will charge up to a certain point and then it will start blinking red I don’t know if blinking red on my charger is fully charged or no? I think possibly old
Also what do you suppose the minimum battery Percentage is before I should probably get back on the charger
To get maximum battery life plug in the charger after each use.
