I have a 2020 Gem E2 that displays a Vehicle Fault (Triangle with exclamation point inside)
When I scroll through I get to the Vehicle Fault Screen (Wrench Symbol is illuminated).
When I hold down the mode button for 3 seconds I get the following three numerical codes:
At the top of the screen: 520609 (on the left side) and the number 5 (on the right)
At the top of the screen: 520610 (on the left side) and the number 5 (on the right)
At the top of the screen: 520547 (on the left side) and the number 5 (on the right)
In all three displays there is a large 0 to the left of the battery charge with the Wrench symbol to the right.
I have seen online that 05 means main relay not closing electrical fault inspect main
relay and fuse.
What do the preceding digits indicate?
Should I just replace the relay and if so is that the Motor Relay?
With this many common faults this almost sounds like a plug/harness issue. Is there a junction plug in back of the car that may have all these wires in a bundle?
I could see that buy why does it also not list the rear right turn light? Does the display have a page down/up mode to see if there are unviewed error codes? That would definitely validate your thought on it being a rear harness connector.
Thanks so much, that is very helpful - I think I can trace it back now and get it sorted out.
BTW where can I find a list of those code errors? The only codes I see on the web are the 2 digit.
It scrolls through the error codes - and I’m only seeing those 3 - it just repeats after that.
It seems like you guys have it down on the rear harness - Thanks, I appreciate the input dougl.
