Heres the Controller Manual.
heres the pictures
I found a wiring diagram.
[QUOTE=chasehoe;10714]I found a wiring diagram.[/QUOTE]
Thanks. That helps a lot. Here is the replacement charger that was put in it. There is NO AC wiring going into the charger housing. There is no leads coming out to the batteries. The only thing that is hooked to the charger is a small plug with about 6 wires. I could use a manual that this charger first off.
is there a way to just hook the gas pedal right to the controller?
