Testing for batteries problem
Many EV researcher nearly have batteries problem,usually they need some way to test their batteries’ performance,capacity/energy/SOC/charge-discharge perfor etc…
like the photo above, a tester can help you to set any work steps to test the performance of your batteries
use a data software to check the test data and analyze the batteries whether in good work status,software interface as below:
For EV battery pack testing the more important demand for tester are battery consistancy testing and evalution,SOC testing,single cell voltage and temperature monitor etc…
You also can inquiry the detail from me.
