Inwo
1
Have an Omron pulse counter wired to standard tach plug.
Self powered. Use to test motor tach output, on or off vehicle.
Simple way to verify hall effect output from motor.
Also to check gear ratio.
Plug it in.
Roll car 1/4 turn of tire. Reads ratio direct.
For more accuracy roll car two turns and divide by 8.
$25 delivered or borrow it if you have a one time use.
[quote=Inwo;30221]Have an Omron pulse counter wired to standard tach plug.
Plug it in.
$25 delivered or borrow it if you have a one time use.[/quote]
$25!!! used/unuse.!!!:o
it is better to borrow one, or visit some mechanic who might have the tools you need
