T5 Controller Parts Availability
Good Evening, I have what seems to be a common Code 66. Failed Mosfets for Forward and Reverse.
Is it possible to purchase the whole card or do I have to sharpen up my soldering skills? Any help is appreciated. I did a search and found multiple places that will repair for $500 plus. I am confident I can make the repairs but would rather replace the whole card, mosfets as a second resort and paying full price for a rebuild is my last resort. Still searching on where to get the parts from for a T5.
Thanks In advance. Have a great evening.
A few on here have replaced them in t4. I would not expect t5 to be much different.
Mosfets are usually marked with good numbers. If not replace all 4 with appropriate generic parts.
Being the t5 is a newer design, it may have a single full bridge. Same advice applies.
rebuilds are closer to 300 . keep us posted .
If you are OK with a soldering iron replacing the Mosfets is not hard. Search for David’s, Grants and my threads on completing the process.
Thank You, I plan on disassembling tomorrow.
P80nf12 mosfet. Anywhere to get them fast?
Digikey or Mouser…
Ordered from Mouser. 1300 in stock and should be here by Wednesday.
