Spindle castle nut
How tight should this be?
Tighten it until you hear a crack, then back it off a 1/2 turn.
I’m not exactly sure what this means
Machinist / engineer humor.
00-10 used castle nuts and are listed at 74 ft-lbs spec.
I don’t have manuals for 11-12.
'13 shows a different design retaining nut and lists 165 ft-lb.
No idea what they did after that.
In plan words…crank it tight…thanks
74 ft-lb is kind of at the low end of automotive lug nut torque to put it in perspective.
The problem with overtightening anything on a gem is that something often tends to break when you do.
If you are near a Harbor Freight, you can get a mediocre grade torque wrench for $12 w/ coupon. I’d never use it for precision work, but for probably anything on a GEM it’s likely fine.
