I have 2009 eL XD. My unit has heavy duty 5 lug stud hubs. Unit has 7.0 HP motor. I need the torque wrench setting requirements for the front spindle nut. Has anyone else had problems with spindle nuts loosening? I suspect it is due to direct drive electric motor which has 5 times as much starting torque as gasoline engine. Drive lines were more than likely design selected based on HP rating rather than torque values. I now have 8500 miles on original batteries and still running great. Thanks for any help!
I have a Electric impact driver/wrench. I’m pretty sure it’s rated at 500 flbs I never go that tight I hit it with the wrench and as soon as the nut clamps down and starts slow turning I stop I would say 150-200 at the most. I have striped a few rusty ones b4 so they can’t take that much torque
Spindle nuts tend to “not become tight” due to normal bearing wear. If bearing is not noisy just tighten the nut. I dont know the exact spec. How ever I thghten mine to about 70+ foot pounds.
Hello Grantwest & Old_houseboater
Thank you for your help. I had estimated 75-100 ft/lb. When I first had my GEM state inspected, they told me my left front wheel was to loose, GEM only had 114 miles on it. I went through second bi-annual inspection and they would not pass. I told them to tighten the spindle nuts, but he used air impact wrench and I was afraid it was too tight and might crack bearing race. I just do not think he realized it was not a lug nut.
Some additional information, I am a mechanical engineer and design special equipment including house boats, wind powered generation systems and electric powered boats. I am also on ABYC project technical committees and ISO technical advisory group member. If I can be of help, just ask.
I will check to see if it is the manual tomorrow. I pressed the bearing out of an eS this afternoon, it had the “loose nut” too.
The torque spec is 65 Ft-Lb, and Locktite 242 is supposed to be used on the threads.
Thanks, RussJ. That helps a lot.
