Quite a complex rewiring job at T4 controller.
Lots of time and research in making monitor function work.
Simple in theory. Why isn’t this information common knowledge? Or is it?
I couldn’t find it!
If I just share what I’ve learned, there will be a lot of butchered Gem wiring harnesses.
Make some simple jumpers and leads with proper terminations?
Make a complete kit with a switch, switching from run to pc?
Either requires changes to harness. (reversable with proper terminations) It would make little sense to return wiring to original configuration, after programming.
Considerably more involved than the USB programming cable alone.
Will not be able to add it to cable, at no charge, as I hoped.
