Can I leave my Ride 4 Fun charger plugged in all the time? It mentions it has a float charge. I just don’t want to over charge the batteries.
If it was set up properly it should be fine.
That being said-
Has anything changed?
Are you having troubles or signs that something is not right?
Yep, default settings are that it switches to float at the end of the cycle. Display will read “CC” and the status led will flicker orange.
The R$F charger is a rebranded QuickCharge SCO 7210. You can find the manufacturers instructions and a video on programming it on this page
https://www.quickcharge.com/select-a-charge%20on%20boards.htm
Thanks for the info.
