Well, I found the 45 second delay beeper on the firewall by the steering column on my 2007 ELXD. I cannot find the reverse beeper. Any help on its location or how to disconnect it would be greatly appreciated. I have the dash apart and tried listening for the location but it sounds buried.
cut the DB/LG darkblue light green cable on controller
its on pin 10,“reverse buzzer driver”
This is a safety feature
Thank you for your responses. You are both correct.
There is only 1 beeper
On my 2013 E6S the reverse beeper is on the PSDM circuit board. I opened mine up and covered the beeper with some tape to reduce the volume. It still serves its purpose without making everyone cringe. I think I shared photos of this in another post before but can’t recall.
yes but easy to cut cable on pin 10 and also put a on off switch if you want
