E825 starts beeping while driving. I have to turn off ignition switch then back on to stop it. Starts again about 30 seconds later. Cleaned battery connections, replaced ignition switch. Still does it. HELP:)
I am having the same problem, have you had any luck fixing this?
No luck, changed the ignition as some suggested but didn’t fix it. Also cleaned all the connections again. Could be new battery connection lines are needed or a bad battery, haven’t moved forward with those yet.
Thanks. I will try the ignition.
