I have a 2002 e825 that I bought about a year ago. While working on the loose steering issue that I have, I discovered that my speed sensor is bad and has some broken wires. When I pulled the cap off the motor, I discovered that the magnet has a hairline crack in it that almost looks too perfect to not be normally there. Is that true or should I replace it while I’m doing the sensor?
I ‘think’ I have the D&D Blue Motor but I can’t find any markings on it. The magnet has a ‘1’ on it as well. At least I figured out why my speedometer isn’t working!
Thank you!
