What is the best way to remove and reinstall install and new imputshaft?
Is it best to remove the entire Transmission or can the imput shaft be easily removed and reinstalled while the transmission is in the car.
The shaft can easily be replaced with the trans in the vehicle. You will need a large snap ring tool such as KD 3151. The shaft will pull straight out fairly easily. You will also need the rubber bushing and possibly the o ring. There is a different shaft for each gear ratio. The new replacement input shafts with Polaris part numbers will have an open bearing and separate oil seal.
I have done extensive study on bearings that are available for GEM input shafts. I firmly believe My rework of your shaft with a real seal is the way to go.
HOWEVER: IMHO an NTN 6005LLU - NTN6005LLU/3C - NTN6005LLU/5C bearing stand the best chance of holding the oil in a GEM gearbox.
They are available on Ebay for about $20. After my experience with other types and brands of bearings. I firmly believe this would be money wll spent.
I would surely like to sell my kit but IMO this is the best alternative bearing for the application.
If any of you tech guys want to get into the technical reasons, PM me. (the secrets in the seal contact area)
I have a 2002 GEM that I am replacing the differential with one I purchased from Grant West, who said that you rebuilt the unit. It does not have an input shaft and I am pretty certain that I will need a new one based the sounds from my current unit. Are you able to supply the input shaft and what information do you need from the differential.
April 14
Thanks,
Chuck Holliman
Palm Desert, CA redprowler@gmail.com
Old_houseboater, could you please send me pricing etc. on your Input Shaft replacement kit? I have a 2003 E825. Michael Renaud (207) 636-6453 mjr7546@gmail.com
Hello again sir- i think I have decided to take off the motor and see if I
can tell whether it is the motor having too much play to make all the noise
or, if it is the input shaft. I believe NEV Accessories carries a “kit” if
it is the motor, correct? If it is my input shaft, and I purchase one from
you, do you supply the “kit” as I’ve seen that includes the one snap ring
and sealed oil part? Also, I would love to hear any pointers prior to my
"tear-down" for I have never done it before. Any assistance would be
extremely helpful with great gratitude…
I’m surprised that there are no videos out there for folks to watch
pertaining to removing and/or replacing the input shafts. I think it would
be extremely beneficial for folks like me that have never attempted it
before. On a fixed income looking to save a few $$$…
i would like to give a huge shout out to a couple folks that have been extremely kind & helpful…Rodney & Richard Gallop are two very resourceful guys! I asked questions and got instant correct answers along with exacy ways to perform the tasks I had to do in order to get my GEM car up & running. If you ever need ANY part(s) for your car, i strongly suggest you contact Richard. Great jobs guys & I can’t thank you enough!!
Good afternoon sir. Would you be able to tell me what type of controller i
might have in my 2003 E825. Also the difficulty involved in going to a more
powerful one?
