This is just “idea” of where the light bar is going to sit
Once I get the height of the bar Dialed I will chop off the excess at the top w
here I want the bar I will choYou can’t tell from the angle of the photo but the roof is quite curved @ my mounting point and to create a level mounting surface the Square stock Aluminum needed to be cut and sanded quite a bit to fit the curve of the roof
Lights look good- how well do they work in lighting the road? I can handle the mounting as you’ve done it- what was involved in wiring the new lights?
The Stock wireing has 3 wires High Beam (yellow) , Low beam and ground (black) easy
