Golfcartevolution
Hi, new here. have a GEM e2 that has ignition switch removed looks like it is a two wire. turns on all accessories when i connect. it is 72 volt has no sticker with the year on it. it will not move . the solenoid has 72v on both sides with no click. the only click is the micro switch in accel pedal . It has the sealed converter black finned box. charger is still there and I can hear it click when plugged in seems to be working. Do I need a controller? I do some STAR but mostly ezgo club car. Any help or diagrams out there? thanks:wave:
It was a relay on the right front of dash i made a jumper and it was fine so i replaced it
It was a relay in right side of dash easy plug and ride away
Very common problem.
