Hello. I’m new to the forum and working on a Gem eLXD. I’ve searched around and can’t seem to find the “Veh Fault” code I’m experiencing anywhere.
It’s 520518: 5. Best I can find is it may have to do with the main circuit or even the Trombetta solenoid. It seems to have an arc and slight melt but does click when the ignition is turned.
Pushing the handbrake starts the “Whirrrr” but no forward or reverse and there is no physical microswitch for the accelerator. If I keep the ignition on, the Main solenoid clicks every few minutes without pressing the pedal.
Other troubleshooting I’ve done include, battery test, checked fuses and Connectors, disconnected secondary battery (behind dash) and fuse for an extended period and Reconnected.
Any thoughts?
