I am trying to fix a 2014 Gem e2 that spontaneously stopped working. Motor and controller details below.
The user at the time said that the buggy was reversed out but when the mode was changed to go forward and the accelerator pedal pressed, there was no motion and error 45 was displayed.
I’ve taken a look and the motor doesn’t run in any mode (high, low or reverse). With the front wheels on axle stands, handbrake off, the master disconnect switch on and the ignition switched on, I hear a click from the master relay in all modes when I depress the accelerator pedal, but the motor doesn’t run. In “high” mode, a very slow application of the pedal causes error 81 to be displayed. If the application of the accelerator pedal is quicker, error code 45 is displayed. In “low” or “reverse” modes, no error code is displayed.
I interpret Error 45 as reporting “Armature transistor did not turn off properly: Replace the motor controller”. I don’t know where to start with this.
I interpret Error 81 as reporting “No tachometer signal is detected: Defective wiring between tachometer and the motor controller. Replace tachometer.”. I checked the wiring between the tachometer and the motor controller with my meter and its fine. I measured 12V across the black and red wires. I tried operating the buggy with the tachometer disconnected and the behaviour seemed the same so its possible that the tachometer is broken but I can’t see why that would prevent any motion at all in the motor or cause error 45. But I suppose its possible.
My strategy has been that the error 45 is likely to be the real culprit but maybe investigating the error 81 (which might be easier) might point me to a common fault. I was thinking perhaps of a dodgy connector or damaged wiring. But I didn’t find any sign of damaged wiring. I checked that the connectors were securely seated.
Motor: Part No.GU3-4002, 2412501 class H
Controller: FSIP catalogue number IC3645SR7A353T6
One rather surprising (but probably unrelated) discovery is that the big orange cables between motor and the controller appear to be swapped. The one that is labelled “<- MA1 CA1 ->” actually goes from Motor A2 to Controller A1. I don’t believe this is relevant to the problem I am seeing - its inconceivable that someone came along and swapped the wires.
Can anyone suggest a route forward? After seeing videos of the inside of the controller and the effort required to restore suitable thermal sinking for the MOSFETs, I am reluctant to dismantle the controller if it can be avoided.
Thanks,
Richard
