Gem e2 2005 Need calipers
Hi, looking for calipers for my 2005 Gem e2 shortbed front right and left calipers ?
Check out arctic cat atv parts, I believe 02 500 4x4 parts will work. My 08 elxd uses an arctic cat wheel bearing and a lot of the front end parts look the same as the wheeler parts. The only difference I can tell on the caliper is the gem has 2 bleeder valves and the atv has 1. If you try it out let us know how it works for you.
Hi thank You very much
Any luck finding calipers?
Hi, I’m sorry that I didn’t get back to you, I bleed the brakes and work out fine.
Jack
