I have a 2017 GEM E4 that occasionally displays an odd error code. I’m working with the dealer to try to resolve what it means (description is very cryptic), but in the process I got a document from the dealer that lists these codes. It is a different list than what I’ve seen in other threads, and thought it might be of some interest. I tried to upload it, but it is in PDF format (looks like a scan of a hardcopy doc) which is apparently not allowed. Any suggestions on how to post it?
Hi
what error code you got ?
We aren’t allowed to publish Copy righted material. However we can share it with each other.
Would appreciate if you would email it to me. I want to add it to my Library of GEM Information.
Rodney (moderator)
Done. BTW, the error code I’m seeing is 520228: 31, which apparently means “Position encoder error root cause not known”.
ok thanks are that a speed encoder problem ?
can you run car ?
Polaris is saying its probably an issue with the electric power assist steering. The fault so far has only shown up when we first turn on the GEM, and only occasionally. It almost always clears when I turn off the GEM, then turn it back on. Only once did this not clear the fault, which went away eventually. Haven’t noticed any problems with the power assist not working.
I have a 2016 eL XD with an error code and would really appreciate a copy of the code list please.
If you could email it to me at manike@gmail.com that would be great.
Thank you
Just sent this. Old_Houseboater, I had sent this to you before when you first requested it, just sent again.
HI
520517-12 says Motor controller bad Intelligent device Or Component
Hi, can you send me the error code list please? My email is rikee777@yahoo.com.
BTW I’m getting 3 fault codes: 520547, 520609, and 520610.
Thanks!
520547 LEFT TAIL LIGHT DRIVER CIRCUIT
Voltage above normal or shorted to high source
Voltage below normal or shorted to low source
current below normal or open circuit
520609 LEFT TAIL LIGHT DRIVER
As above
520610 RIGHT TAIL LIGHT DRIVER
As above
Hello can you also send me the error code list? In a 2019 EXL I am getting an error code #520503. Thanks in Advance
520503 BMC Charger
Current Below Normal Or Open Circuit
thanks so much for the quick reply!
I too would like the list of fault code emailed to me. Michael@cartsmax.com. Thank you! Working on a 2016 e6 with the round dash cluster.
