A 72 V gem motor works on 72 V battery but when I check with a voltmeter connected to the controller when I hit the gas fully it sometimes drops to 68 or 67 V what is the minimum voltage for this motor ?
Voltage drops under load. This is normal. Voltage reading under load can drop into the 60s
I think minimum start voltage is 65V - but like @Old_Houseboater said while running the voltage can dip below that.
