Hello,
I have a 1999 GEM that has a short in the lighting. My right front turn signal stays on and the right indicator stays on as well. I removed all fuses and it still stays on. I removed the cover on steering and found that someone tapped off the turn signal green and red and ran wires to the signal indicator lights. I am looking for a wiring diagram.
Message me with your email and I can send PDF.
Email rodneyadiehl@aol.com for diagrams.
Usually turn signal errors can be cured by replacing the turn signal assembly.
This is a common problem.
I ordered a new turn signal switch, relay and wire harness. Waiting for all that to come.
Just an update on this issue. After replacing the turn signal I still had the same issue with indicator staying on. I did find out that the DC/DC converter was in need of replacement under a safety recall. The Dealer replaces it for free! That fixed the issue.
Now I’m trying to find out why I have 8 wires in my fuse block when the manual only shows 6… I added a Stereo and a large amplifier/ subwoofer that I wanted to add to the fuse block.
