Front wheels on my 2002 gem are locked up. When I jack the front end
Up the wheels turn with expected motor resistance. The controller is also shot having thrown a 66 code. Any thoughts?
Code 66 is a transistor failure in control.
Do you have a local “electronic” guy to help?
I am going to send my controller to ride 4 fun. The 66 code should not cause the wheel problem right?
That will be a costly fix.
You say locked, but it turns?
Only with the wheels off the ground
Are the rear brakes locked?
Or if wheels turn opposite, the motor is locked.
I will check the motor.
Motor is locked. Now what?
Rodney is your guy for that. Take it off to start.
