Has your husband come up with a price for everything?
Looks great! Where did you purchase your wheel adapter? Also how thick are they and do you know the offset of the wheels?
The voltage spoof goes on pin one of the motor controller.
I just sent another update to you I think. I don’t look at the forum often and not really sure how to upload pdfs or pics… I found a 3 clusters that need to be reconfiged as well as some of the covers my husband had made. 15k would buy everything. I have more items here and there that I will throw in. Just trying to sort through. I can walk you through the inventory over facetime as well. I think I posted my phone number to you, hopefully it didn’t go out to the forum. I changed the order alphabetically by description. I thought that was easier to browse through. You are welcome to call me 239-. Jennifer
Here’s the list
Sorry for the delay. I am not certain how to send you pics. An email possibly? I am happy to send photo and the list in pdf format. I have photos of pretty much everything. Please let me know if you have any interest in purchasing. Jennifer
Current list
| PARTS INVENTORY -2002 FORD THINK NEV- FORD MOTOR COMPANY GENUINE PARTS | |||
| ALL OEM PARTS - MAJORITY PURCHASED FROM SAM GALLOWAY FORD - FORT MYERS, FL | |||
| ALL PART ARE NEW UNLESS NOTED. PARTS LISTED TWICE FOR LOCATION PURPOSES, ADD THE QTY FOR TOTAL STOCK. | |||
| IN ADDITION TO PARTS LISTED I HAVE 7 VEHICLES TOTAL=2 TRUCKS, 3 4-PASS AND 2-2 PASS NEVS LEFT OUTSTIDE FOR MUTIPLE YEARS/RUST/NO BATTERIES OR CLUSTERS IN CARS/BODY PARTS SEEM IN GOOD CONDITION/ONE WINDSHIELD WAS SHATTERED IN ONE 2 CAR I ALSO I HAVE AT LEAST 4 CUSTOM COVERS, 2 NEED TO BE CLEANED. | |||
| Part Number | Name | Quantity in Stock | LOCATION |
| 2E38-A62284-BE00AZ | 4 SEAT REAR STANTION | 1 | STORAGE |
| 23EZ-3082-AA | ARM ASY | 1 | GARAGE |
| 23EZ-3083-AA | ARM ASY | 2 | GARAGE |
| BACK COMPARTMENT MISSING DOORS | 2 USED | STORAGE | |
| BACK LID | 1 USED | STORAGE | |
| 2E3Z | BLADE ASY | 1 | STORAGE |
| 23EZ-5406202-AAA | BOX ASY | 1 | STORAGE |
| 2L1Z-19A487-AA | CLOVER | 1 | GARAGE |
| 2E38-10849-AG | CLUSTER GAGE ASY CLUSTER | 3 USED need recofig | STORAGE |
| 2E3Z-14262-AA | CONTROL ASY | 3 | GARAGE |
| 2E3Z-14B227-AA | CONVERTER ASY | 1 | STORAGE |
| 910-7201 | DELTA MODEL 910-7201 QUI Q 7212 HF/PFC BATTERY CHARGER WITH MOUNTING PLATE AND CORD | 2 USED | GARAGE |
| 910-7201 | DELTA MODEL 910-7201 QUI Q 7212 HF/PFC BATTERY CHARGER WITH MOUNTING PLATE AND CORD | 1 NEW 2 USED | STORAGE |
| 2E38-70400-AE | FENDER | 1 NEW 2 USED | STORAGE |
| 2E38-16005-AF | FENDER FRONT | 1 USED | STORAGE |
| 2E38-16005-AF00WH | FENDER FRONT RHWH | 2 | STORAGE |
| FENDER NOT SURE WHAT SIDE | 3 USED | STORAGE | |
| 2E38-17B859-AAW | FRONT BUMPER | 1 NEW 2 USED | STORAGE |
| FRONT LID | 1 NEW 1 USED | STORAGE | |
| 1E3Z-14526-AB | FUSE | 4 | GARAGE |
| 1E3Z-14526-AC | FUSE | 3 | GARAGE |
| 2E3Z-14526-AA | FUSE | 6 | GARAGE |
| 23EZ-14526-BB | FUSE | 3 | GARAGE |
| 2E38-A11140- | GLOVE BOX COMPARTMENT AND FLOOR COVER | 2 NEW 1 USED | STORAGE |
| 23EZ-2282-AC | HOSE ASY | 4 | GARAGE |
| 2E38-14B331-DK | HRNS ASY LOW CURRENT | 4 | GARAGE |
| 2E3Z-18180-AA | ISOLATOR | 6 | GARAGE |
| KEYS OEM BLANK BLACK HEAD FORD THINK KEYS | 21 | GARAGE | |
| 2E38-4426-AB | LEFT FRONT SHOCK COIL? NEED TO VERIFY | 1 | STORAGE |
| 2E3Z-5422050-AC | LOCK ASY | 2 | GARAGE |
| 2??-2140-AA | MASTER CYLINDER ASY | 2 | GARAGE |
| 6U5Z-17700-B | MIRROR | 4 | GARAGE |
| YL8Z-17700-AA | MIRROR | 1 | GARAGE |
| 2E3Z-2457-AA | PEDAL | 2 | GARAGE |
| 2E3Z-14R262-AA | PKG OF 2 PCS RIVET | 4 | GARAGE |
| PLUGS WITH SURGE PROTECTOR | 4 USED | ||
| 2E38- | REAR BUMPER | 5 USED | STORAGE |
| 1L2Z-15K040-AB | RING | 2 | GARAGE |
| 2E3Z-14R331-BA | RIVET | 12 | GARAGE |
| 23EZ-3A130-AA | ROD | 4 | GARAGE |
| 2E3Z-54512S48-AC | SEAL- RUBBER | 4 | GARAGE |
| 2E38-A62284-AD00AZ | SEAT STANCHLON COVER | 1 | STORAGE |
| 1E3Z-18A124-AA | SHOCK ABSORBER ASY | 5 | GARAGE |
| 1E3Z-18A124-AA | SHOCK ABSORBER ASY | 2 | STORAGE |
| SHOCK ABSORBER ASY (SET INLUDES 2 USED) | 1 | STORAGE | |
| 1E3Z-18A125-BA | SHOCK ASBORBER ASY | 1 | STORAGE |
| 1E3Z-18A125-BA | SHOCK ASBORBER ASY | 1 | GARAGE |
| 2E3Z-4S234-AA | SLEEZE | 4 | GARAGE |
| 1L2Z-19N236-BA | SOCKET | 3 | GARAGE |
| 2E32-1416-AA | SPEED CONTROL SWITCH? NEED TO VERIFY | 1 | GARAGE |
| 2E3Z-13341-AA | SWITCH ASY | 5 | GARAGE |
| 2E3Z-13341-AA | SWITCH ASY | 1 NEW 1 USED | STORAGE |
| TRAY GOLF | 1 | STORAGE | |
| F8RZ-13350-AA | TURN SIGNAL SWITCH | 2 | GARAGE |
| 2E3Z-9D878-AA | WIRING ASY | 1 | GARAGE |
i need a window and photos of the cars cruzhdf@gmail.com
Cartywho - thanks for the recommendations!! I bought the steering wheel setup you suggested (changed the quick release) …
I did have to use a thick shim / washer to bolt the adapter hub to the column.
I have not figured out how to use the factory horn wiring - the factory hub connects the two (2) push pins …How did you wire up the horn ?
I cut the center of the old steering wheel out so I could use the original contact plate. I welded that to the spacer.
Thank you @David_Illingworth !
I popped the ring off and will look how to connect it to the base (given that it appears to be plastic, maybe I can just glue it to the base…not sure it is even necessary, just need to run the wires from the horn button)…I’ll post some pictures later this week!
I cut the entire center section out and used it. If you can make just the ring work that would be great.
More part request help….
So the soft brake lines from Centric are out of stock with no planned production… I had two lines fabricated for the front and found the fittings to be quite unusual 10x1.25 (fyi) and for the fronts you definitely need the fitting bent at 45degrees …
Looking at the various hard lines, I could probably replace those as well… should I make these (and hope I can reuse the fittings) or has someone found factory parts?
I would just make your own brake lines. Get a tube bending tool and a double flare kit. Reusing the old fittings is fine. Practice making the flares if you’ve never done them before.
Glad you found someone to make the flex hoses.
