To install EZ STEER
1 Jack and block front of car so you can work under it.
2 Turn off main switch
3 Remove clamp bolt from steering gear
4 Remove package tray and lower dash
5 Remove column plastic covers
6 Unplug turn signal switch only
7 Remove steering wheel and cut wire ties on steering column
8 Remove 4 instrument cluster screws and lift it over column and set aside
9 Remove turn signal
10 Remove old steering column.
11 Place EZ Steer in position and connect to steering box and tighten securely, IMPORTANT THAT YOU DO THIS FIRST
12 Place EZ in position against aluminum angle iron and mark and drill (2) 3/8 holes
DO NOT TRY TO LINE UP WITH EXISTING HOLES
13 Install 2 bolts and tighten slightly
14 The lower brace should be close to the angle iron . It can be bent to suit if required and can be shimmed with flat washers if not up against the angle.
15 If you like the angle of the column drill and bolt the lower brace
16 Tighten all the bolts
17 Install the turn signal
18 Install the instrument cluster
19 Plug in the turn signa
20 Tywrap the column cables
21 Let the car down
22 Center and install the steering wheel . Ride around and MAKE SURE the wheel is correct. Tighten the nut LOOSELY You may have to adjust later.
23 You will have to trim the column plastic pieces.
24 Replace the lower shroud and the dash
25 Enjoy
Let me know how made out.
