Hi everyone,
I have never done this sort of project before, so I’m sorry if I overlooked something obvious when I was selecting my parts that won’t allow them to work together.
I have been viewing these forums, the ev album, and several other places with EV-related topics, and I found some cars with the best specs, and I want to pretty much make a similar car cheaper. I was looking into using an original 300zx as the donor car, mostly just because I like it for its looks. But if that’s not possible, I’m just going to go for any light car in good condition (I don’t already own a donor car).
I need a fair mix of range and performance, but I think I’d prefer performance a little bit over range. However, my commute is a little over 8 miles each way, so I need the car to be able to go about 20 miles on a single charge. I want good acceleration, and to be able to go at highway speeds. My budget is 6-7k.
I have selected a number of parts that I think would do well in my EV. I wanted to know what you think of my selection, where I could improve it, where I could shave off a bit of the cost, anything that won’t work together properly, etc.
Powersonic PG-12V42FR - 12 Volt/42 Amp Hour Sealed Lead Acid Long-Life Battery with Threaded Insert - 6mm STUD (10 batteries for a total of 120 volts, or 12 batteries for a total of 144 volts)
http://www.gotbatteries.com/items.asp?params=batteries/LeadAcid/1/PowerSonic/Powersonic%20PG-12V42FR/PG12V42%20FR/SL140/35L140S3
Cafe Electric Z1K LV Controller
http://cafeelectric.com/shop/index.php?main_page=product_info&cPath=1&products_id=27&zenid=f8f0faca9daacc4cdd09d8ab65e00be7
Motor, Advanced DC #FB1-4001, 9.1", single shaft
http://www.evparts.com/prod-MT2119.htm
Powersonic PSC-124000A Sealed Lead Acid Battery Charger - Automatic Switchover 12 volt/4 Amp Nominal
http://www.gotbatteries.com/items.asp?params=search/all/1/all/35S206S1
Todd PC40LV DC-DC converter
http://www.theautochannel.com/mania/repair/TODD.html
That’s my list, please let me know if anything’s missing.
Also, what do I need to know about maintenance? What’s involved in watering the batteries (although the batteries I found apparently don’t need to be watered)? What about replacing the brushes on the motor? How often does this stuff need to be done? I’m sorry for the noob questions, but I hope you understand that everyone has to start somewhere!
Thank you for your time and patience,
Scott
EDIT: I’ve decided it would be a good idea to add where I got my inspirations.
White Zombie (although unfortunately he used too many custom parts to make it feasible for me)
http://www.evalbum.com/35
Old Reliable
http://www.evalbum.com/140
Joule Injected
http://www.evalbum.com/836
Thanks once again!
EDIT #2
Would this be an even better idea than getting all the parts separately?
