DIY honey extrator
You will need some type of reduction. Best to just find a 90 deg gear motor.
Slowest ac motor is 1800 rpm. 5:1 is a good place to start.
The closest you can match maximum motor speed to what you need the better.
The vfd will overspeed the motor if needed.
