hey guys I just picked up 2 motors one is a stock 3.5 and the other is a 5hp
is there any benefit to the 5 hp? speed torque? the 5hp has an extra black plug coming from the brush area of motor with oblong plug What is this for`?
Also the 5hp spins at approx 500 less rpm than the 3.5
I use my truck version for utility use and although speed is fun torque often is needed more than speed I am currently using a 8.9 gear and think I’d be better off with the 10,9 or 12 how much speed will a sacrifice using the lower gear ratios
[quote=SCOUT202;27797]hey guys I just picked up 2 motors one is a stock 3.5 and the other is a 5hp
I use my truck version for utility use and although speed is fun torque often is needed more than speed I am currently using a 8.9 gear and think I’d be better off with the 10,9 or 12 how much speed will a sacrifice using the lower gear ratios[/quote]
Rodney,
I received my used controller from Arizona and installed it i replaced my 3.5 with the other 3.5 both ohmed out fine. I have 6 brand new battery’s i tested voltage into the controller it is 75.9 the large contactor is engaging. When pedal is depressed motor whines but no rotation. tried a different motor with same result> I’m stumped any suggestions?
did some voltage checks at motor key on or off readings are the same
A-1 to ground 40.0 volts
A-2 to ground 40.0 volts
F-1 to ground 33.6 volts
F-2 to ground 33.7 volts
Key on forward gear pedal depressed engages large relay and motor does nothing whine coming from controller.
