Below are 2 parts lists for refurbing GEM Gear Boxes.
Parts required to refurbish 8.9 and 10.35 Gear Boxes with New Seal Type input shaft assembly
(2) Axle bearing 6004 2RS 20x42x12 MM $2.44 ea
(2) Differential carrier bearing 6007 RS (remove seals)35x62x14 MM $6.46 ea
(2) Intermediate shaft bearing 6303 RS 47x17x14 (remove seals) $3.71 ea
(1) Input shaft kit (Seal type) Includes bearings $190 27 TOOTH.
(1) Input shaft bearing 6005 RS 25X47X12 (remove seals) $3.67 EA.
(1) Input shaft small bearing 6203 2RS 40x17x12 (remove seals) $1.28 ea
(1) Input shaft seal 25X47X6 $4.00 ea.
(2) Intermediate shaft seal cap (freeze plug) EZGO part #601064 From any EZGO Dealer or Orange County Monster Cart. $4.12 ea.
(2) Axle Seal 24x40x10 MM $4.69 ea
(1) Tube Permatex Blue $7 Any auto supply store
All parts available on Ebay except as noted
Parts list to refurbish 8.9 and 10.35 and 12.44 and 14.76 GEM Gear Boxes With Old style input shaft.
(2) Intermediate shaft bearing 6303 RS 47x17x14 (remove seals) MM $3.71 ea
(1) Input shaft small bearing 6203 2RS (remove seals) 40x17x12 $1.28 ea
(1) Input shaft big bearing NTN6005LLU 25x47x12 $25.89 This IMHO is the only bearing currently available that holdS oil.
(2) Axle Seal 24x40x10 MM (CHECK THICKNESS) $4.69 ea
(1) O’ring you only need 1 intermediate shaft has the caps Viton Oring #133 1 13/16" id x 2" od bag of 10 $6.20
I have never change out the axle shaft bearings or seals. Never found them bad. Shame on me
Thanks to Gwest for his input on these lists.
