Hello,
I developed an easy solution to avoid having the cable on the floor, it’s available on Kickstarter:
Hello,
1/2 as long for shipping as a solution to mentioned issue?
The end of the first wire wound into a receiver for outer half.
Obviously a smaller id spiral with spread coils.
Or maybe use a threaded rod coupler.
I like it, having two Tesla’s and two Gem cars it seems we are always walking around or over charging cords. I was thinking of something like a air hose reel, that way the whip could be up out of the was as well.
@Inwo, Thanks for the 2-part suggestion, yes, the first proto was exactly that, with a tube as a coupler, but in the end it’s too complex to build vs the shipping cost gain, so the one part will probably win out
Order quickly if you’re interested, the 20 first to order get a rebate
@MikeKC yes, once this is hopefully in series prod, the next version would be to figure out how to achieve that with a fixture from the ceiling.
