Still having a hard time locating this exact charge port. I looked threw all of the Hubble Hubble website. They don’t seem to have it. Marinco makes somthing close BUT it has the twist and lock plug. And you can’t retrofit it to the straight 3 blade?
If you have not drilled the hood yet I have changed over to a completely different style inlet for my GEM. I have the GEM style on my boat and several other things and as they age the cords do not hang on tight enough to keep from falling out. The new inlet is a water tight twist lock style that is much smaller and is rated at 20 amps instead of the 15.
