Do you have any balance boards left for the lifepo4 cells? I’m looking for 25 of them.
Yes, I do.
$5 each cell.
Just sent you a PayPal for these.
Sent from my iPhone
On Jun 15, 2020, at 5:10 PM, Inwo via Electric Forum electricforum@discoursemail.com wrote:
| Inwo
June 15 |
Yes, I do.
$5 each cell.
Visit Message or reply to this email to respond to Inwo, cbepps.
To unsubscribe from these emails, click here.
I was thinking you used them before.
Yes, cut all the wire off short.
I have a punch to make the holes for battery studs.
A grinder or mill will work. Or maybe clip both holes and break out the center piece.
As long as there is a small part of the copper foil left to make contact your good.
Did I send the ones with a copper extension on each end? They can be discarded. Or possibly bent into a “U” and fastened under the boards.
“what ever works”
Ask on forum to see how others used them.
I use these clip-on fuse holders for my testing. I bet a bare ring terminal will work the same.
Bend the barrel up through a hole in board and solder.
Thanks. I’ve used them previously but you had punched them and wires were removed so this is a different experience for me.
I’ll need to find/buy a punch as this is the only one I have on hand.
Try an angle grinder. Cut a notch in from the end. Or a side cutter to snip the middle out between the holes.
I used a pair of 8” side cutters to carefully snip the PC board. Be careful though the small LEDs are really fragile. Hand was pretty tired after doing 25 x 2 x 2 cuts however.
