Testing ways to raise Min-Max voltage levels for T4 controller.
Seems to work. Need brave volunteer.:boxing:
Tested my car at 90 volts. Snowing yesterday. Only went up and down the street.
Plan is to make plug in modules to raise voltage by a set amount.
Used a +12 in mine.
Shown is a +5 that Grant may try to raise his cut-off voltage from 60-65 volts.
Being a spoof, it won’t raise the safe voltage of internal mosfet drivers.
Relies on built in safety margins that may or may not be adequate.
Much like overspeeding a motor.
Is it safe? Well maybe!
