As far as I can tell mostly stock 2013 E6. Wheels tires are the 14" ride4fun package. Controller and batteries toast. Ran up until about a year ago until controller started throwing error 77 at random times and also whenever going downhill, controller was replaced, same issue so its been sitting until upgrades are sorted.
Use is flat land (one small 30’ tall hill), almost always less than 20 miles per day.
What’s the current state of the art for this year E6?
I am also interested in upgrading a stock 2014 E4 to lithium. Thanks.
I have the medium lithium pack, stock motor on my e2 with a service bed & stock motor
Pulls all the overpasses & hills at 25mph
Will smoke the tires when starting out if I floor it
Over 25 miles range at full speed
I might be able to help out… depending on what you end up deciding to install. I’m out in the San Carlos /SDSU area. Only problem is my calendar is jam packed until September… You’re welcome to come out and check out my AC setup in my 2016 e4
