I need more range 50+
I need a Plug n play solution
My understanding is that the BMS manages charging & identifying bad cells. Do I need to interact with the BMS? Can the bms be preconfigured
Is a wired solution adequate?
I’ve had very little success with bluetooth/wireless stuff more complex than a mouse or connecting to a wifi network, I do have android phone & tablets that are reasonably current
I understand having the rare wired solution, could make
Looks like I can slide a battery pack from the the back
Is there an appropriate charge profile on a 2013 charger
What else is needed?
Who wants to sell me a package?
Yeah you right
Being able to run the pack all the way down without stressing about wounding the pack, there’s no going back on a LA pack once you’ve drained them too much…
From what I’ve read lithium packs, don’t like being completely drained for extended periods, other than that robust
My Boy fun, hotrod brain tells me bigger, faster, drive to Tahoe or Carson City, Black Rock, which is more fun on a motorcycle anyway Bigger packs have higher voltage, which introduces issues which could affect reliability
My actual use case could occasionally go as far as 30 miles total
22s SDI it is send Inwo the $500 deposit?
When is the balance due?
Do I need anything beyond a piece of plywood for the battery frame
I’m considering a layer of pressure treated 2 x 6, would be easy & forever
Anything works and it’s all you need to do. Everything else is included.
Everything from sheet plastic/aluminum, pvc 1x8s from home store, to Unistrut have been used.
I’ll pm the payment info.
Scan qr code for app. Pair 1234 pw 123456
Battery is jump start if bms gets turned off.
Top open? Picture?
Tie down ratchet straps over all works. Screws to shelf helps too.
Battery comes with a vinyl cover. This battery may have been built for a specific client of Scotts.
I can send one if it’s not there.
No BMS should not be loose, the blue wire should be connected to B- on battery.
I thought Scott was on the same page as the rest of us as far as what was supplied.
Scanning the bms does take you to the download site. I can send a link to it as well.
If you find more issues, I may need to replace battery or find someone to put the pieces together. @ScottyD@AssyRequired can you help me out here?
I have the right app, I’m not very phone/app skilled, I’ll bang away later,
I’m in touch with Scott, he can send whatever enclosure, seals, BMS mount are needed
Here’s the loose component
Optional spoof. Needed to get the most range from battery. We can explain later after car is running. Another may be needed for charger which I will supply.
Plug and play yes, but a few minor details. Sorry about getting off on the wrong foot. It will be worth the effort.
Should I be mounting as far forward as possible in the battery tray?
I’m eyeing up the space under the seat & front of the battery tray as additional storage
