I have 96+ volts on my lithium conversion and on my stock, unmodified T2 controller I am getting 36mph max. I also have car rims and tires. Lithium is really the way to go to get the speeds you are looking for.
Purchased a D&D motor - will update when done…Between this and a boost battery or 2, should be ok. Can I go as high as 96v, or stay at 84v? I was thinking of replacing my Delta q with a matching charger to allow charging of all batteries…
What D&d motor did you Get? I ended up getting an es132-69 motor from them and it seems about the same power as the stock motor
84v dq chargers are rare. 96v are common. Or you could get a c10325 Chargery that does everything from 12-102v 1500 watts.
It also has power supply mode for testing and charging dead batteries.
Rodney, Does your O’Reilys charge shipping on top of that price? None of my local stores stock these
I let them know a day ahead and they are they are tere by 8AM.
In a message dated 3/31/2019 3:03:42 PM US Eastern Standard Time, electricforum@discoursemail.com writes:
Gemmy
March 31
Old_Houseboater:
O Rilley 31DCM battery
Thanks, @Old_Houseboater. All my local stores want to charge me $20 (EACH ! ) for shipping
(San Diego area)
@Gemmy, I’m in San Diego( Pacific Beach ) and searched for that battery. It said it was not in stock but then I set my store to Garnet Ave and searched again( 31DCM ) and there was a 31DCMJ which was the same price and in stock.
Thanks, @dougl
I’ll try a broader search
